Log Files
The Viz Virtual Studio log files are located in C:\ProgramData\vizrt\VizTH, and consist of the following files:
  • Tracking Hub Console Log File:
    • VizTH.log
  • Tracking Log Files:
    • VizTH_rcvX.log where X is a number. The files can for example be VizTH_rcv1.log, VizTH_rcv2.log, etc.
    • VizTH_sendX.log where X is a number. The files can for example be VizTH_send1.log, VizTH_send2.log, etc.
  • Timing Log File:
    • VizTH_timingX.log where X is a number. The files can for example be VizTH_timing1.log, VizTH_timing2.log, etc.)
The increment of the number (X) is when the first file reaches a size of 1 MB. All log files change to the next number at the same time.
  • Exception Log Files:
    • In the event of an unrecoverable exception error, the information provided in the user interface dialogue box are automatically saved to a log file using date and time as filename, for example 2016_04_20_16_30_30.log.
