Booleans
Booleans are a data type with only two possible values; true or false. The Channel Recorder accepts YES, NO, TRUE, FALSE, ON, or OFF as Boolean values, where:
YES,TRUEandONare positive values switching a flagOn, andNO,FALSEandOFFare negative values switching a flagOff.
Timecodes
Timecodes in Channel Recorder have the form <hh>:<mm>:<ss>:<ff>, where
<hh>represents the hour in 24 hour format,<mm>is minutes,<ss>is seconds, and<ff>refers to the frame number, according to the frame rate.
Example: A zero timecode looks like this: 00:00:00:00.
