The clock is a very important component of Channel Recorder. If no clock is present Channel Recorder might fail in performing scheduled, loop or frame accurate recordings. There are four sources of resolution: input, genlock, configuration and internal.
For clock type GENLOCK
, the priority is given in the following order:
Input
Genlock
Configuration
Internal
For clock type INPUT
Input
Configuration
Important points to remember are:
The resolution from the configuration is only used when there is no input or genlock signal detected.
Internal resolution is only relevant when the following is true:
There is another application using Matrox board.
The application in question is using a different frame rate family.
Clock type
INPUT
is the simplest and should be used unless there is a compelling reason not to use it.
Note: For IP boards, 2059
is used by default.
