The Text FX Vertex Color plug-in adds a color per vertex effect to the text.
Supported Pipelines
Classic Render Pipeline
(tick)
Viz Engine Render Pipeline
(error)
Note: Works only if the text is set to texture (does not work with geometry text).
Text FX Vertex Color Properties
  • Color Bbox: Defines the reference bounding box, global for the entire text, or local for each character.
  • Color Direction: Defines the color gradient shape. Available options are; top left to bottom left, top right to bottom right, top left to top right, bottom left to bottom right, top right to bottom left and four corners.
  • Color Level: Sets the level of the color (0.1 to 1.9). Default is 1.0.
  • Top and Bottom Left and Right: Sets the color and alpha value for each edge.
  • Color use Alpha: Enables alpha.
