The Text FX Slide plug-in allows you to create a sliding animation of the characters on the X, Y and Z-axis.
Supported Pipelines | |
Classic Render Pipeline | |
Viz Engine Render Pipeline |
Text FX Slide Properties
X, Y and Z Distance: Defines direction and distance of moved text.
Show Direction: Enables and disables view of movement vector.
