The Text FX Arrange plug-in allows you to arrange characters in either a circular or a wave shape.
The characters can be animated on the selected shape by animating the offset value.
Supported Pipelines
Classic Render Pipeline
(tick)
Viz Engine Render Pipeline
(tick)
Text FX Arrange Properties
  • Offset %: Moves the characters on the shape. 100% means one full rotation of the text on the circle.
  • Scale %: Sets the text on the shape. The parameter does not scale the characters itself, but the kerning of the characters.
  • Shape: Changes the shape of the character layout to Circle or Wave.
Note: The shape of the text transformation is not visible in the Scene Editor while the Text Editor is active.
Circle Parameters
  • Diameter: Sets the diameter of the circular shape.
  • Positioning: Defines the position of the text on the circular shape:
    • Relative: Maintains the text spacing of the text object.
    • Absolute: Distributes the text evenly onto the circle.
  • Direction: Sets the direction of the text on the circle to either Clockwise or Counterclockwise.
  • Rotation: Rotates the characters on the X-axis.
  • Align: Rotates the characters on the Z-axis to align the X-axis with the tangent of the shape at the characters position.
Wave Parameters
  • Length: Sets the wave length. A high value creates many and small waves, a low value creates fewer and bigger waves.
  • Width: Sets the width of the wave.
  • Height: Sets the height of the waves without altering the number of waves as the Length does.
  • Shift %: The wave usually starts at the height 0. The shift value moves that point, thereby moving the texts position on the wave structure. Setting Shift % to 100% brings you back to the beginning.
  • Damping: Modifies the amplitude of the wave curves.
