The System Time plug-in creates a variety of time and date settings based on the system time.
System Time adheres to the standard  IEEE Std 1003.1, 2004 Ed.
System Time Properties
  • format (aAbBcdDHIijlmMpSUwWxXyYzZ/:,.): Sets the format of the system time.
  • Language: Sets the language format of the system time. Options:
    • Default (system specific)
    • English
    • German
    • Norwegian
  • Seconds offset from system clock: Sets the number of seconds the system clock should be offset (default is 0).
  • Hours offset from system clock: Sets the number of hours the system clock should be offset (default is 0).
  • System time zone: Sets the system time zone.
  • Show Time Zone: Shows the result of the system time zone.
  • Lower Case Text: Shows all text in lower case.
Time Zone: tzn[+|-] hh[:mm[:ss] ] [dzn]
  • tzn: Time zone name (for example, PST).
  • hh,mm,ss: Offsets from the local timezone to UTC (not the reverse).
    • For time zones ahead of the set one, the time difference is negative.
    • For time zones behind the set one, the time difference is positive.
  • dzn: Daylight-saving-time zone (for example, PDT).
Examples: EST5EDT, PST5PDT, GST-1GDT
