The Pixel Shader plug-ins are part of the PixelFX plug-ins set.
Viz Artist does not support more than one general Shader on a Container, or in a nested fashion. In some cases, PixelFX, by its nature, does support multiple Shaders per Container. Some have high cautionary indications. Some are very light. Some are stackable, and others are not.
The default path for the Geometry plug-ins is: <viz install folder>\plug-in\<plug-in name.vip>
The following Shader plug-ins are located in the PixelFX folder:
- PixelFXLensFlare
- pxBCubic
- pxCCBase
- pxEqualize
- pxGaussianBlur
- pxGradient
- pxInvert
- pxLensDistort
- pxMotionBlur
- pxNoise
- pxPixelate
- pxPosterize
- pxRecolor
- pxRipple
- pxSparkle
- pxTurbDissolve and pxTurbWipe
- pxTurbulence
- pxTwirl
- pxWaves
Common Properties
The PixelFX Shader plug-in icons themselves are divided in half with one side showing the visual effect with the plug-in and the other without it.
