The Multi Panel plug-in is a geometry plug-in that helps create the virtual representation of the video wall setup. It allows to create multiple different shapes from rectangular to curved ones. Multi Panel contains the actual video walls dimensions and its alignment in the real studio.
Multi Panel can create multiple segments within the same geometry, easily allows it to have rotated tiles seamlessly merged together if the dimension of the tiles are the same (symmetrical video wall setup).
Multi Panel Properties
  • Mode: Defines how the properties are being used to generate the video wall geometry.
  • Width: Defines the width of the geometry/single segment in centimeters.
  • Height: Defines the height of the geometry/single segment in centimeters.
  • Angle: Sets the rotation angle around the y-axis in degrees/angle in degrees between two consecutive shapes.
  • Segments: Sets the number of subdivisions/consecutive segments.
  • Bottom UV: UV coordinate for the lower edge, where y = 0.
  • Top UV: UV coordinate for the upper edge, where y = Height.
  • Left UV: UV coordinate for the left edge, where x = 0.
  • Right UV: UV coordinate for the right edge, where:
    • Geometry: x = Width
    • Segment: x = Width * Segments
  • UV Rotation: Rotation Angle around the UV center.
