The Image Clip plug-in is designed to play back a sequence of still images (for example, TGA or TIFF) rather than playing a movie file. It also supports alpha channel and various play modes (looping, swing, etc). The plug-in loads all images to RAM, then loads only one image at a time to texture memory. The download time is almost linear to the size of each frame. Preparation for this plug-in should be uncomplicated as most video applications has support for saving out TIFF. Since it plays the sequence from memory, one obvious benefit is that once loaded into memory it does not access the hard drive at all. So if it is needed to play back ten different sequences at once, ImageClip is pretty much the only solution. It is ideal for looping small animations such as logos. The drawback is that it consumes system memory.
Remember to keep track of how much memory each sequence needs, to avoid running out of memory on the Viz Engine machine. Running low on memory makes the system start caching parts of memory to the hard drive and it may not play the sequence and graphics in real-time.
Image clip should not be used with very large clips in Continuous and Array mode. Since all images are loaded into memory a large number of images or a large image size would require large amounts of memory.
Memory can be calculated as follows:
Number of images * Image width * Image height * 3 (or 4 when using alpha)
The use of Thread mode solves the memory issue, but it takes longer to request a frame. Therefore it should be used only in a slow motion image clip.
Images for an image sequence should be placed in specific folders. For example if you out many flag image sequences, you would have a separate folder for each flag image sequence. Make sure that the images are named sequentially (for example, england001.tif, england002.tif, england003.tif etc).
Note: This plug-in is located in: Plugins -> Container plug-ins -> Texture
Known Issue: If the Image Clip plug-in is used to display compressed image sequences like .vbn, please be aware that any image operation like resizing (keep under option) or format conversations (for example, to luminance) will fail because of the missing original data. This is a known limitation.
Image Clip Properties
Image: Sets the image path and the first image you would like to use in the animation. Do not use clip names with numbers (except the counter (for example, 000, 001, 002, etc.)).
Play Mode: Sets the play mode:
Once
Loop
Swing
Animation
Anim-Dissolve
Reverse: Reverses the animation (not in Animation play mode).
Animation Position: Sets the animation position (for example, where to start and stop the animation). The position is a counter for the number of images in the folder referenced by the Image setting. This setting is enabled when Play Mode is set to Animation.
Play Speed: Sets the speed of the animation.
Advanced: Enables the advanced settings (see below).
Time Mode: Enables time specific settings.
Stand Alone Image: Enables the same clip to be played in different speeds.
First Image: Defines the first image of the animation.
Nof Image: Defines the number of images, relative to the First Image, that should be part of the animation.
Geo Ref:
Info: When changing the Crop or Scale By parameters, Reinitialization is needed.
Crop: Crops the image (by percentage) from the left, right, bottom and top side.
Scale By: Enables the scale setting.
Scale: Scales all images to the closest power of two. When not selected, automatic texture coordinates are applied so the image fits the texture.
Keep Under: Forces the image size. For example if you have selected 64, the image is trimmed to the size 64 x 64.
Base Path:
Format:
Weather:
Blend Images:
Dissolve Speed:
Control Texture Map:
Memory Type: Sets the memory type.
Continuous: Uses one big chunk of memory to store all images.
Array: Uses divided chunks of memory to store all images.
Thread: Loads only requested frame on-the-fly, with [n] frames loading time limit.
Mapping:
Play (button): Plays the animation.
Stop (button): Stops the animation.
Reinitialize (button): Reinitializes all settings.
To Add an Image Clip
Add a Container to the Scene Tree.
Add the Image Clip plug-in to it.
In the Image Clip properties click the Browse () button to locate the folder that has the required images.
Select the first image in the sequence.
Click OK. The image sequence now loads into the ImageClip plug-in, and is visible in the scene.
Click Play to test the image sequence. If you change the image sequence and you need to reload it, click the Reinitialize button.
Change the Play Mode to Loop to play the image sequence continuously. The image sequence starts playing automatically.
Change the Play Mode to Animation to animate the image sequence frame position to control the sequence within the Stage Editor. The image sequence now stops playing and a new property is revealed that is called Animation Position. This refers to the frame number that is currently shown for the image sequence.
Animate the Animation Position value. The Animation Position maximum value is restricted to the number of images.
Another possibility is to create a file with a .vln extension. This file includes the base path and also the names of the images to load. In this case the images must not have a counter number in their filename. You can handle this file as an ordinary text file.
Load the .vln file instead of loading an image file located in a directory.
Example:
BASE_PATH
'C:/clip/images'
'radar_200504110800.png'
2005_04_11_10:
00
'radar_200504110815.png'
2005_04_11_10:
15
'radar_200504110830.png'
2005_04_11_10:
30
'radar_200504110845.png'
2005_04_11_10:
45
'radar_200504110900.png'
2005_04_11_11:
00
'radar_200504110915.png'
2005_04_11_11:
15
'radar_200504110930.png'
2005_04_11_11:
30
'radar_200504110945.png'
2005_04_11_11:
45
Note: Viz Engine does not interpret between Key Frames, so if you choose to slow down an animation then the motion is not smooth.
