The CFX Rotate plug-in allows you to create an effect where the containers rotate on the X-, Y- or Z-axis.
Note: This plug-in is located in: Plugins -> Container plug-ins -> ContainerFx
CFX Rotate Properties
  • Anchor Horizontal: Sets the anchor point for the containers on the horizontal plane.
  • Anchor Vertical: Sets the anchor point for the containers on the vertical plane.
  • Use Axis: Defines on which axis the containers rotate.
  • Begin: Sets the initial rotated position of the containers.
  • End: Sets the ending rotated position of the containers.
