The Container FX Plus Plus plug-in allows you to set a number of effects on a container’s set.
Note: This plug-in is located in: Plugins -> Container plug-ins -> ContainerFx
CFX Plus Plus Properties
  • Position Wrap
    • Extrapolate: Continues the direction of the spline when set above 100% or below 0% of Path Position.
    • Clamp: Stops the string on the spline endpoints.
    • Repeat: Causes the string to move to the other spline endpoint as soon as it moves over the endpoint.
    • ContainerFx: Positions containers by the relative spline of each container using the ContainerFX parameters.
  • Scheme Type: Defines how the container-set looks at 0% and 100% progress.
    • In -> In: at 0% first container is at the beginning of the spline, at 100% last container is at the end of the spline.
    • In -> Out: at 0% first container is at the beginning of the spline, at 100% first container is at the end of the spline.
    • Out -> In: at 0% last container is at the beginning of the spline, at 100% first container is at the end of the spline.
    • Out -> Out: at 0% last container is at the beginning of the spline, at 100% last container is at the end of the spline.
  • Progress (%): Animates the progress of the effect(s).
