Object Tracker Release Notes
Version 1.2 | Published May 25, 2023 ©
Object Tracker 1.2.0
Release Date: 2023-05-17
These are the release notes for Object Tracker version 1.2.0. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since release 1.1.0.
images/download/attachments/125454661/objtracker_overview.png
Object Tracker allows tracking individual or multiple objects within a video to focus on the key parts of the action. This fully software-based and only requires video input.
Improvements
  • Added a new filter algorithm that improves tracking quality in very noisy use cases.
  • Add Faces tracking algorithm.
  • Add 2D Pose tracking algorithm.
  • The configuration has been simplified.
  • Removed the dependency from the Tracking Hub.
Compatibility Notes
Object Tracker 1.2 is compatible with:
  • Viz Engine version 4.4.0 and later.
  • Viz Arc version 1.8.0 and later.
Documentation
Documentation for Object Tracker and related products are available on the Vizrt FTP and on the Vizrt Documentation Center:
Support
