Media Service User Guide
Version 2.3 | Published February 19, 2018 ©
Installation and Configuration
Media Service is shipped as a single installer:
Media_Service_and_Coder-x86-<version>.exe
where <version> are numbers indicating version, release and build-number.
IMPORTANT! Always read the Release Notes for any last-minute information.
Requirements
Media Service is compatible with modern Windows standards and should run on Microsoft Windows version 7 and above. It has been tested on Microsoft Windows versions 7, 8 and 8.1. Media Service is designed to work with Viz Engine but does not require it to run.
The Media Service server requires:
Microsoft .Net client libraries, version 4.5.1 or above.
If running on Windows 7, the Coder component (used by Media Service) requires SP1 or higher. It is possible, though not normally done, to run the Coder component on a different machine than the server running Media Service. It is only Coder that requires Windows 7 SP1.
TCP/IP network connectivity to clients. The standard port is 21099 and this port must be open if using a firewall.
