Versions other than those listed here are not officially supported, unless expressly stated in the documentation.
The following systems are supported:
Adobe Premiere Pro
Graphics Plugin for Adobe has been tested against, and supports the following versions:
  • Premiere Pro CC 2024 (24)
  • Premiere Pro CC 2023 (23)
Note: This plugin works on both Windows and Mac machines.
Avid Media Composer
Graphics Plugin for Avid supports the following versions:
  • Avid Media Composer 2024
  • Avid Media Composer 2023
  • Avid Media Composer 2022
  • Avid Media Composer 2021
The following systems support the Avid Extensions (AVX) 2.0 System Development Kit (SDK):
  • Avid Digital Studio (DS).
  • Media Composer (Older Release and Post Adrenaline HD release that can run software only), Media Composer Adrenaline, and Media Composer Adrenaline HD.
  • Symphony and Symphony Nitris.
  • Xpress, Xpress Pro, and Xpress Pro HD.
Grass Valley EDIUS
Graphics Plugin for EDIUS supports the following versions:
  • EDIUS X
Note: The latest version supporting Edius 8 and 9, is version 2.3.1.
Note: This plugin only works on Windows machines.
Apple Final Cut Pro
Graphics Plugin for Final Cut works together with Apple Final Cut Pro X. This plugin only works on Mac-machines.
Quantel Rio
Graphics Plugin for Quantel works together with Quantel Rio 4.3, or later. Version 2.0 of Graphics Plugin supports earlier versions of Quantel QEffects/Rio (version 4.2).
