Graphics Plugin for EDIUS Release Notes
Version 2.5 | Published March 06, 2024 ©
Graphics Plugin for EDIUS 2.5.0
Date: 2024-03-06
These are the release notes for Graphics Plugin for EDIUS 2.5.0. This document describes the user-visible changes that have been made to the software since version 2.4.0.
New Features
  • New Configuration Tool for Graphics Plugin (NLE-3040).
Fixed Issues
  • Pilot Edge 3.0 wasn't compatible with plugin version 2.4.0 (NLE-3024).
  • Engine provides flipped image when using PNG compression in NLE (NLE-2971).
  • The progressive mode was used when the video was in interlaced mode (NLE-3067).
  • Rendering issues in interlaced mode with RLE compression on Edius (NLE-3068).
Compatibility Notes
  • The Graphics Plugin for Edius version 2.5.0 is only compatible with Edius X.
  • The Graphics Plugin for Edius version 2.5.0 is not compatible with Edius 11, 8 or 9.
  • The remote rendering feature is not yet supported on Edius X.
Documentation
Documentation for Graphics Plugins are available at the Vizrt Documentation Center:
Support
