Graphics Plugin for EDIUS Release Notes
Version 2.4 | Published February 18, 2022 ©
Graphics Plugin for EDIUS 2.4.0
Date: 2022-02-18
These are the release notes for Graphics Plugin for EDIUS 2.4.0. This document describes the user-visible changes that have been made to the software since version 2.3.1.
Compatibility Notes
The Graphics Plugin for Edius version 2.4.0 is only compatible with Edius X.
The Graphics Plugin for Edius version 2.4.0 is not compatible with Edius 8 or 9.
The remote rendering feature is not yet supported on Edius X.
Known Issues
Installing over Graphic Plugin for Edius 2.3.1 or earlier may cause issues. It is advised to uninstall any previous versions before installing 2.4.0.
Documentation
Documentation for Graphics Plugins are available at the Vizrt Documentation Center:
Support
