Graphics Plugin for EDIUS Release Notes
Version 2.3 | Published May 04, 2021 ©
Graphics Plugin for EDIUS 2.3.1
Date: 2021-05-04
These are the release notes for Graphics Plugin for EDIUS 2.3.1. This document describes the user-visible changes that have been made to the software since version 2.3.0.
Fixed Issues
Fixed an issue when connecting to an https Pilot Edge using the "Untrusted SSL" option in Graphics Plugin configuration (NLE-2739).
Graphics Plugin for EDIUS 2.3.0
Date: 2021-02-10
These are the release notes for Graphics Plugin for EDIUS 2.3.0. This document describes the user-visible changes that have been made to the software since version 2.2.2.
New Features
Added server-side rendering using XRE Server (NLE-2619).
Fixed Issues
The plugin would not close the connections to Viz engine when a project was closed. The connections were also not being closed when graphics were unused (NLE-2664).
Trying to create a Vizrt graphic would take multiple clicks after opening Edius (NLE-2663).
Fixed an error whereby it was possible to create multiple Vizrt graphics at the same time using the Edius timeline context menu (NLE-2717).
Documentation
Documentation for the Graphics Plugins are available at the Vizrt Documentation Center:
Support
