Graphics Plugin for Avid Release Notes
Version 2.2 | Published April 20, 2020 ©
Graphics Plugin for Avid 2.2.2
Release Date: 2019-12-16
These are the release notes for Graphics Plugin for Avid version 2.2.2. This document describes the user-visible changes that have been made to the software since version 2.2.1.
Fixed Issues
Avid Media Composer would sometimes crash after opening the graphics editor (NLE-2419).
Preview in graphics editor now also works if the Viz Engine/Connection Broker port is 50107. Previously only worked if port was 50007 (NLE-2347).
Graphics Plugin for Avid 2.2.1
Release Date: 2019-03-14
These are the release notes for Graphics Plugin for Avid 2.2.1. This document describes the user-visible changes that have been done to the software since version 2.2.0.
Fixed Issues
Editors did not open with an existing element if one was present (NLE-2209).
Removed an Update popup dialog that could appear in newer versions of Avid (NLE-2258).
Fixed a rare issue where the preview would disappear for all plug-in instances if a pilot1 frame failed to display when still-image playback was turned on.
Graphics Plugin for Avid 2.2.0
Release Date: 2018-11-30
These are the release notes for Graphics Plugin for Avid 2.2.0. This document describes the user-visible changes that have been made to the software since version 2.0.1.
New Features
The plug-in now supports Viz Pilot Edge on both Windows and MacOS! Select Viz Pilot Edge as the User Interface in the NLE Configuration and point to your Viz Pilot Edge hostname using the Pilot Edge URL parameter. Launching the editor then opens the Payload Editor with Viz Pilot Edge (NLE-2111).
Added support for Stop Points. Importing graphics with Stop Points now displays the Stop Point Editor, which allows the user to alter the pause durations (NLE-1608).
Added configuration option for Still image playback. When this is checked, scrubbing and playback of unrendered effects will show a still image of the pilot1 preview point (NLE-2133).
Realtime playback is now supported. The plug-in now previews graphics during playback without needing to render the effect. Still-image playback is recommended when trying to play graphics in high resolution without first rendering.
Fixed Issues
Fixed a rare issue where existing graphics data could bleed over after swapping to a new graphic (NLE-2183).
Fixed missing title in NLE Configuration window while minimized (NLE-1407).
Fixed an issue where Tidy would trigger cleanup prematurely during scrubbing (NLE-1270).
Documentation
Documentation for the Graphics Plugins are available at the Vizrt Documentation Center:
Support
