Graphics Plugin for Adobe Release Notes
Version 2.4 | Published April 02, 2024 ©
Graphics Plugin for Adobe 2.4.1
Release Date: 2024-04-02
These are the release notes for Graphics Plugin for Adobe version 2.4.1. This document describes the user-visible changes that have been made to the software since release 2.4.0.
New Features
Added a button to open the Graphics Plugins documentation on the Configuration Tool (NLE-3036).
Logging on the Graphics Plugin Configuration Tool (NLE-3034).
Fixed Issues
Viz Engine provides flipped image when using PNG compression in NLE (NLE-2971).
Graphics Plugin couldn't edit templates if no editor was previously configured (NLE-3045).
The editor window didn't show automatically on MacOS Ventura and newer (NLE-3060).
Scrolling behavior on the Graphics Plugin Configuration Tool (NLE-3063).
Rendering issues in interlaced mode with RLE compression (NLE-3069).
Known Issues
High values cannot be saved on time fields in the Graphics Plugin Configuration Tool (NLE-3042).
Graphics Plugin for Adobe 2.4.0
Release Date: 2023-12-12
These are the release notes for Graphics Plugin for Adobe version 2.4.0. This document describes the user-visible changes that have been made to the software since release 2.3.5.
New Features
New Configuration Tool for Graphics Plugin (NLE-2925).
Fixed Issues
Viz Pilot Edge Editor reports ERR_ABORTED when loading initial URL (NLE-2907).
Documentation
Documentation for the Graphics Plugins are available at the Vizrt Documentation Center:
Support
