Security Advisory
Recommendations
After installation of the software, please proceed with the following advisories:
Change the default password for Graphic Hub Admin user: GH Manager Tools > Administer users & groups.
Enable http authentication in GH Terminal: Options > Advanced Settings.
Change Graphic Hub Terminal password (see above): Options > Change Terminal password.
Use SSL encryption for Graphic Hub Rest.
Disable Remote Access for WiBu Codemeter Webadmin and use SSL (Configuration > Basic > Webadmin)
Remove any unneeded services.
Ports used by Graphic Hub and Components
The Graphic Hub server requires a limited number of open network ports. The following table lists the ports used for Graphic Hub server connectivity:
Port Number |
Protocol |
Used for |
Other components |
427 |
TCP, UDP |
OpenSLP |
22352 |
TCP, UDP |
Codemeter |
Graphic Hub & Graphic Hub Terminal |
19394 |
UDP |
Manager for Terminal 2 |
19395 |
TCP |
Terminal 2 |
19396 |
TCP, UDP |
Naming service |
19397 |
TCP, UDP |
Graphic Hub |
19399 (configurable) |
TCP |
Terminal 3 (HTTP) |
Graphic Hub REST Service |
19398 (configurable) |
TCP |
REST service (HTTP) |
Deploy Agent |
19391 |
TCP, UDP |
Deploy Agent High Availability |
19392 |
UDP |
Deploy Agent |
19393 |
TCP |
Deploy Agent |
ImEx Agent |
19390 (configurable) |
TCP |
ImEx Agent (HTTP) |
Additional Ranges |
Since Graphic Hub Deploy Agent 2, Graphic Hub Manager 5, GH REST 2, and Viz Artist 3.8.2, these clients do not require any port exemption rules on the client side firewall configuration. However, for earlier versions, all ports must be open on the client side.
