Introduction
This is the Graphic Hub Administrator Guide, which provides the information needed to configure and operate the Graphic Hub.
Feedback and Suggestions
Graphic Hub Log Files
A Graphic Hub overall report, which contains all Graphic Hub log files and additional system information, can be generated in the Graphic Hub Terminal.
All services installed on the same machine will be included in the export.
If there is no Graphic Hub terminal running on the workstation where the Graphic Hub Deploy Agent is running select and generate these log files:
Graphic Hub Log files
Location: <current Graphic Hub data directory>/LogFiles
Purpose: Graphic Hub runtime and error information.
System Event Log
Location: Start > Run... > eventvwr.exe > Event Viewer > Windows Logs
Purpose: Information from the current windows system.
To create: Right click on System and select Save all Events as...
Application Event Log
Purpose: Windows crash information of programs
To create: Right click on Application and select Save all Events as...
Vizrt Event Log
Graphic Hub Deploy Agent system log (only exists if Graphic Hub Deploy Agent is installed).-
Location: Start > Run... > eventvwr.exe > Event Viewer > Applications and Services Logs
Purpose: Deploy agent event log.
To create: Right click on Vizrt and select Save all Events as...
Graphic Hub Component Logs
In general, all Graphic Hub Components log files containing important information:
Purpose: Configuration and logs of the Graphic Hub component
Graphic Hub REST Log files
A Graphic Hub REST report, which contains all relevant log files and additional system information according to GH REST, can be generated in the Graphic Hub REST web interface.
If this is not possible select and generate these log files:
Purpose: Connection, error and event logs of the Graphic Hub REST.
Graphic Hub ImEx Log files
A Graphic Hub ImEx Report, which contains all relevant log files and additional system information according to GH ImEx, can be generated in the Graphic Hub ImEx web interface.
Purpose: Connection, error and event logs of the Graphic Hub ImEx Agent.
