Version 3.1 | Published July 11, 2018 ©
List of ports used for Graphic Hub network connectivity
Since Graphic Hub 3, the server requires a limited number of open network ports. The following table lists the ports used for Graphic Hub server connectivity:
Port Number |
Protocol |
Used for |
427 |
TCP, UDP |
OpenSLP |
19390 |
TCP |
ImEx Agent (HTTP) |
19391 |
TCP, UDP |
Deploy Agent High Availability |
19392 |
UDP |
Deploy Agent |
19393 |
TCP |
Deploy Agent |
19394 |
UDP |
Manager for Terminal 2 |
19395 |
TCP |
Terminal 2 |
19396 |
TCP, UDP |
Naming service |
19397 |
TCP, UDP |
Graphic Hub |
19398 |
TCP |
REST (HTTP) |
19399 |
TCP |
Terminal 3 (HTTP) |
Since GH Deploy Agent 2, Graphic Hub Manager 5, GH REST 2, and Viz Artist 3.8.2, these clients do not require any port exemption rules on the client side firewall configuration. However, for earlier versions, all ports must be open on the client side.
