Viz Licensing Administrator Guide
Version 3.1 | Published May 07, 2024 ©
Introduction
Vizrt is releasing an update to the License Portal that enables customers to manage licenses, using WIBU Systems. This documentation guides you through the different options and processes.
Improvements and Bug Fixes
Kindly check the Vizrt Licensing Release Notes for the latest changes.
This software protection program is implemented in Vizrt software as part of major new releases. Prior versions covered by software protection can continue to run on the node-locked licensing.
Legal
Copyright © 2024 Vizrt. All rights reserved.
Disclaimer
Antivirus
Vizrt does not recommend or test antivirus systems in combination with Vizrt products, as the use of such systems can potentially lead to performance losses. The decision for the use of antivirus software and thus the risk of impairments of the system is solely at the customer's own risk.
There are general best-practice solutions, these include setting the antivirus software to not scan the systems during operating hours and that the Vizrt components, as well as drives on which clips and data are stored, are excluded from their scans (as previously stated, these measures cannot be guaranteed).
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
