To run the Viz World Client and Server, the following software is required:
  • Viz World Client (Map Editor) version 24.1.
  • Viz World Server 24.1 (It is recommended to install the server on a separate machine).
Note: Installing Viz World server and Viz World client on separate machines is recommended.
  • Viz World database version 24.1.
Note: Viz World database is recommended to be installed on the same machine as Viz World Server for easier configurations.
  • Microsoft Visual C++ 2010 Redistributable Package.
  • Microsoft Visual C++ 2019 Redistributable Package.
  • Microsoft .NET Framework 4 or later is required for the Map Designer, Map Builder, and World Map Editor.
Note: Running any of the installers version 24.1 installs all the required software listed above which should not be uninstalled.
Viz World 24.1.0 was tested with:
  • Viz Engine 5.3.2
  • Viz Pilot 8.9.3
  • Viz Pilot Edge 3.3.0
  • Viz Pilot Data Server 9.3.0
  • Viz Trio 4.4.0
