Component | Minimum Configuration | Recommended Configuration |
CPU | Eight cores with 2.4 GHz frequency | 2 x Intel i7 CPU (or equivalent Intel Xeon processor) |
Memory | 8 GB | 16 GB |
Disk Space | A full installation requires at least 2 GB of available disk space. Optional data packages require between 4 GB to 1000 GB of available disk space. | |
Operating System |
Note: Viz World Server and Viz World Classic will not function while connected using Windows Remote Desktop. | |
Network | A redundant (teamed) setup with two Gigabit network adapters is recommended. | |
Power Supply | A redundant power supply is highly recommended. | |
Note: When more than one server runs on a single machine, it is necessary to use the recommended system configuration described above. See Server Allocator Configuration.
