The Map Designer has two toolbars, and most of the functions are the same as the Map Editor Toolbar. The functions that differ are described in this section.
Horizontal Toolbar
The horizontal toolbar is the same as the Map Editor Toolbar, with the exception of:
New Project: Creates a new map template (see Getting Started).
Open Project: Opens existing map template files.
Save Project: Saves the current map template file.
Save Project As: Saves the current map template file as a new file.
Vertical Toolbar
The vertical toolbar is the same as the Map Editor Toolbar.
