Viz World Classic allows you to draw a smooth path, using Bezier curves, and animate an imported image, movie, text item, or drawing on a shape layer along the path.
To Create an Animation Path
  1. Move to the first frame of the animation.
  2. Select the Path tool and drag the image, text item, or drawing to the initial location:
  3. Move to the last frame of the animation.
  4. Drag the image, text item, or drawing to the ending position. A line is drawn to show the animation path, with dots indicating the position in each frame:
To Convert the Path to a Curve
  1. Move to an intermediate frame of the animation.
  2. Drag the image, text item, or drawing. The path curves through the new position.
To Adjust the Path
  1. Drag one end of the tangent handles extending from a point on the curve:
  2. Hold down CTRL to drag a tangent handle independently of the other one.
To Align the Image, Text Item, or Drawing to the Angle of the Animation Path
  1. Click the Match rotation to path button on the Properties panel for the image, text, or shape layer:
