Tracking Hub is a console program for Viz Virtual Studio, it collects data from tracking systems (cameras and objects) and stores this information. This tracking data is provided to Viz Engine at a configurable time or after a delay. To achieve exact tracking, many configurations are stored and provided to the user.
The Tracking Hub currently has these tracking drivers installed:
Tracking Hub has native support for the following protocols. The name in brackets is the protocol identifier as it appears in the Studio Manager tracking system dropdown.
FreeD (
freed) — see Description of the FreeD ProtocolFreeD A0 (
freeda0)RTHead (
rthead)XML Tracking (
xmltracking) — a self-definable protocol for special solutionsMotion Analysis (
motionanalysis) — it is possible to work with two MA instancesmo-sys (
mo-sys) — with lens informationTrackmen (
trackmen)Trackmen Mocap (
trackmen-objtr)Vicon (
vicon)Libero (
libero)Libero TC (
liberotc)Spidercam (
spidercam)Spidercam Fielddolly (
spidercamfd)Spidercam FrameB (
spidercam-frameb)Flair (
flair)Thoma (
thoma)Stype A5 (
stypea5)Stype HF (
stypehf)Camreginfo (
camreginfo)Technodolly (
technodolly)Skycam (
skycam)HD Skycam (
hd_skycam)GSS Geopoint (
gssgeopoint)Kuper (
kuper)Kronomav (
kronomav)Telemetrics (
telemetrics)Arraiy (
arraiy) — only with a Vizrt lens fileEagle Eye (
eagleeye)GeoPro (
geopro)Cable Cam (
cablecam)Cable Cam 2 (
cablecam2)Sony (
sony)Sony D0 (
sonyd0)Vips / Airpixel (
vipsairp)
OpenTrackIO is implemented but not yet part of a released build. It will appear in this list once the feature is merged.
Protocols supplied by a plug-in
Besides the native protocols above, Tracking Hub loads protocol drivers as DLL plug-ins written with the plug-in API. NCam and Cincraft reach Tracking Hub this way, so they are not listed as native protocols.
Protocols and certified systems are not the same thing
Tracking Hub parses these protocols and sends the translated data to Viz Engine. A protocol listed here does not mean a tracking system using the same name is certified — see Certified Tracking Systems for the systems that are. Conversely, a certified system does not appear here under its product name: Shotoku and NCam are certified systems that speak one of the protocols above, and XPecto is the protocol implementation behind the trackmen entry.
