The Viz Virtual Studio 1.9.0 release focuses on new tools that assist the operator during setup, especially when setting up XR sets.
The main new features in this release are:
Video Wall Editor
Viz Virtual Studio 1.9.0 introduces a new Video Wall Editor for setting up video wall geometries, especially for XR sets. It creates the video wall scenes in Viz Engine, as well as test scenes for easy alignment adjustments.
  • Wall layouts: One-Corner, Two-Corner, Curved and Back Wall layouts, including right-aligned walls.
  • Vertex-based setup: Walls are defined by their vertices. Measured points can be mapped directly to the wall geometry, and auto-alignment fits the wall to them.
  • Test scene: A generated test scene shows on the engine right away whether geometry and alignment are correct.
  • Wall groups: Walls can be grouped and each group routed to a different engine.
  • NDI preview: The engine output can be previewed through NDI inside the editor, cropped to the area of the wall.
Engine Color Correction
A new tool creates automated color correction look-up tables (LUTs) for Viz Engine scenes. XR engines can adapt to the color space of the real video wall, giving a seamless transition between the real and the virtual extended set.
  • Automatic calibration: The engine output is captured, compared with reference colors, and a 3D LUT is generated to correct the difference.
  • Calibration log: A separate window shows each step of the calibration and its results.
Data Viewer & Diagnostics
Tracking analysis and troubleshooting tools are now combined in the Data Viewer.
  • Tracking flow: The tracking flow view has moved into the Data Viewer, so live and recorded tracking data are inspected in one place.
  • FBX export: Tracking data can be exported as FBX for use in other 3D and post-production applications.
  • Receive Timing: A new tool in the Tools menu shows when tracking data is received, to help find timing and delay problems.
  • Communication logging: Communication between Studio Manager and its services can be logged for troubleshooting.
Other Improvements
  • Lens calibration: An in-progress calibration can be saved and loaded again later. Reference points can be adjusted and individual lens points reset. The Lens Tool has four more targets, and printed target sizes are kept. Lens data dumps are on by default, cleaned up automatically, and can be deleted manually.
  • Services: Camera services can be renamed and filtered. Hostnames are shown in the service views, and the service status display is clearer.
  • Perspective view: The camera can be controlled with the mouse, including scroll to translate.
  • Stability: Loading a configuration shows a busy indicator, and removing services is faster. Fixed a crash when deleting presets, plus several smaller UI fixes.
