The items listed below must be checked before an installation can be done on site. Before an installation can be started make sure:
Camera adjustments/shifts should always be set by camera personnel before any lens calibration is done. After any adjustments/shifts are set, the camera cannot be adjusted without being reconfigured.
Cables: Who is in charge of the cabling before doing an installation?
Tracking: What are the tracking system protocols?
Transfer of tracking data: How is tracking data transferred and what kind of cables are used?
Synchronization sources: What type of synchronization sources used?
Blackburst
Tri-level
In case Viz Engine is selected as the sync source, Tracking Hub must run on the same machine. Then the following sources can be selected in Viz Engine:
SDI input 1 or 2
NDI video source (input 1 or input 2)
PTP
Location of the Viz Engines: Do you have physical access to the machines?
Coordinate system: What are the coordinate systems for the tracking system(s) used?
Make sure that there are no firewalls enabled.
System Requirements
This section details the system requirements.
Synchronization
The Tracking Hub needs some sort of synchronization method on the machine it is installed. This can be:
A running Viz Engine installation, or
An installed Plura synchronization card.
Note: If sync sources is not found, Tracking Hub can still be used in free running mode. Free running is not intended and should not be used for production. It can, however, be used to experiment with tracking on a laptop. For use in production, either Viz Engine or Plura synchronization is necessary.
Note: 32-bit Operating Systems are no longer supported. For versions 1.2 and later, Tracking Hub and Studio Manager are available in 64-bit only.
Minimum Hardware Configuration
Minimum 16 GB Ram
Dual-Core Intel CPU
10 GB of free disk space
NVIDIA P2000 Graphics Card
OpenGL Hardware-accelerated Graphics Card
Info: Minimal Hardware Configuration provides sufficient resources for running a Tracking Hub configuration.
The new automated lens file calibration introduced with this version requires additional GPU processing power. To benefit from this feature, use the Recommended Hardware Configuration.
HP Z4 G4 - 12-Core CPU
64 GB Ram
2x Gbit RJ45
30 GB of free disk space
NVIDIA RTX 4000 Ada
Setup Required for NDI Workflow
HP Z4 G4 - 6-Core CPU
32 GB Memory
2x Gbit RJ45
256 GB SSD for OS
512 GB SSD for Data
NVIDIA RTX A4000 /16 GB GDDR6
Supported Hardware and Software
Windows 10 (64-bit) LTSC
Viz Engine 3.9.0 (either 32-bit or 64-bit) or later, recommended Viz Engine 4.2 or higher
Plura PCL-PCI and PCL-PCIe (L, LV, 3G) timecode reader cards (Driver 5.34)
Important: The PCL-PCI L card can only read timecodes and can NOT be used for synchronization.
Studio Manager requires .NET framework 4.5.1 or higher.
