Export and Import in Template Wizard
Export and import in Template Wizard is similar to export/import in Director, with some differences related to playlists:
To import playlists, you must first specify a Media Sequencer for Template Wizard to connect to using the ini file or the command line. If no Media Sequencer is specified, Template Wizard will attempt to connect to the localhost for the playlist import. See Specifying Command Line Parameters for Template Wizard.
Note: In order for the Export tool to work correctly, the Viz Engine must be On Air before Template Wizard starts.
For a full description of the import and export tools, see Export and Import in Director.
