Database Administration
The database installation for Viz Pilot is a typical Oracle database server installation.
Vizrt’s standard installation of a Viz Pilot database uses the service name VIZRTDB. The SQL schema and table creation scripts add the user PILOT with password PILOT which make up the schema name and the default credentials that all Viz Pilot system applications are configured to use. This can be changed either during or after installation.
