Installing Viz Pilot Edge for ActiveX Based Systems
Some newsroom systems support plugin applications, but not HTML plugin applications like Viz Pilot Edge. Show Edge, an HTML wrapper for systems that only support ActiveX based plugins, must be installed on such systems.
Run the Show Edge Installer:
  • The Show Edge installer is in the same location as Viz Pilot Edge. Following the location of Viz Pilot Edge at the top of this page, the Show Edge installer is available at: http://pds-host-name:8177/app/pilotedge/ShowEdgeInstaller.exe
    • Run the ShowEdgeInstaller.exe file on the client machine.
    • Show Edge displays Viz Pilot Edge in Microsoft Edge WebView2. ShowEdgeInstaller.exe includes WebView2 Runtime 156.0.4314.50: it installs the runtime, or upgrades an older one. A newer runtime is left as is.
Note: For remote installation on multiple machines, the installation file that includes the --msi parameter must be used. This creates a sub-folder containing the .msi file. In the command line, run: ShowEdgeInstaller.exe --msi
Note: The .msi file does not include the WebView2 Runtime. For MSI installations, install or update the Microsoft Edge WebView2 Runtime on each machine separately.
  • The URL to access Viz Pilot Edge is required during installation.
    • Enter the URL in the installer window that appears after running the .exe installer.
    • For the MSI installation, set the Viz Pilot Edge URL using the PE_URL property: msiexec.exe /i ShowEdge.msi PE_URL="http://pds-host-name:8177/pilotedge".
  • If the MSI installation is used, the default install directory can be overridden with the parameter INSTALLDIR: msiexec.exe /i ShowEdge.msi PE_URL="http://pds-host-name:8177/pilotedge" INSTALLDIR="mypath".
  • Opening the "Show Pilot Edge" application from the start menu opens the configured URL in a browser window.
How to Change the Installed Show Edge Configuration:
  • The URL can be changed with the installer (ShowEdgeInstaller.exe, or MSI) by doing one of the following:
    • For the .exe installation, first uninstall and then re-install Show Edge. Enter a different URL in the installation window.
    • For the MSI installation, it's not necessary to uninstall to change the URL. Simply run with a different URL in the command line: msiexec.exe /i ShowEdge.msi PE_URL="change_the_URL".
  • It can also be changed using the installed executable (the default directory is C:\Program Files (x86)\Vizrt\Show Edge\):
    • Select the default directory and run the ShowEdge.exe located in this folder with the desired URL parameter: ShowEdge.exe url "change_the_URL".
Note: To access help in the command window, go to the installed directory and run: ShowEdge.exe help
