Viz Pilot Edge is a graphics creation tool designed for newsrooms to help journalists and producers to independently create and preview graphics using on-brand, show-aligned templates, making visual storytelling faster and easier.
Template Builder is used by design teams to create customized templates via scene import from Viz Artist, supports scripting (Typescript), and live data integrations.
Key Features
  • Search for graphics templates, elements and media assets.
  • Add and edit content using an auto-generated Fill In Form.
  • Preview graphics.
  • Open and edit videos.
  • Save data elements to the database.
Workflow
  • Fill templates with content and store them as data elements.
  • Move data elements into the newsroom rundown.
  • Scenes are made in Viz Artist and imported into Template Builder, where templates are made.
  • Templates are edited and new templates can be made in Template Builder.
  • The template is saved in the Viz Pilot system and is available to newsroom and control room systems for playout.
Feedback and Suggestions
Support
Copyright ©2026 Vizrt. All rights reserved.
Antivirus Considerations
