Viz Pilot Edge is a newsroom component that is used to create, manage and deliver content to live and taped broadcast productions. Viz Pilot Edge can also be used as a Graphics Plugin user interface in NLE workflows.
Template Builder lets you make customized templates using the scene import or existing templates from Viz Pilot's Template Wizard.
Info: A key feature is that you can add custom HTML panels to templates, giving full control over the template through custom scripting and logic.
Key Features
Search for graphics templates, elements and media assets.
Add and edit content using an auto-generated Fill In Form.
Preview graphics.
Open and edit videos.
Save data elements to the database.
Workflow
Fill templates with content and store them as data elements.
Move data elements into the newsroom rundown.
Scenes are made in Viz Artist and imported into Template Builder, where templates are made.
Templates are edited and new templates can be made in Template Builder.
The template is saved in the Viz Pilot system and is available to newsroom and control room systems for playout.
Note: Changes in the UI made to a template in Template Builder are not available when opening the template in Template Wizard.
Feedback and Suggestions
Support
Legal
Copyright ©2025 Vizrt. All rights reserved.
Disclaimer
Antivirus Considerations
Real-Time Scanning: Keep it enabled, but exclude any performance-sensitive operations involving Vizrt-specific folders, files, and processes. For example:
C:\Program Files\[Product Name]
C:\ProgramData\[Product Name]
Any custom directory where [Product Name] stores data, and any specific process related to [Product Name].
Risk Acknowledgment: Excluding certain folders/processes may improve performance, but also create an attack vector.
Scan Scheduling: Run full system scans during off-peak hours.
False Positives: If behavior-based detection flags a false positive, mark that executable as a trusted application.
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
