This section guides you through management of AWS IAM roles needed for operating Viz Now with your AWS account.
Secure, reliable operations are ensured by first clarifying permissions and adopting these best practices.
Overview
Viz Now requires two IAM roles:
IAM Role Name
Purpose
Used By
viz-now-deploy-infra
Provisions infrastructure via Terraform
Deployment Agent
viz-now-manage
Manages deployed instances
Control Plane
These roles are assumed using AWS STS (Security Token Service), and their ARNs are stored securely in Viz Now.
Prerequisites
  • An active AWS account.
  • IAM Administrator access to AWS.
  • Administrator access to the Viz Now platform.
Update Existing IAM Roles
If your AWS account already has Viz Now IAM roles defined, follow these guidelines to update them.
Note: If your AWS account has no Viz Now IAM roles defined, first see section Creating First IAM Role.
IAM Roles
You will update both the Deploy and Management IAM roles and their associated inline policies.
To update an IAM role in Viz Now
This procedure assumes that your Viz Now user details are already setup in AWS. See the Note above.
  1. Log in to your AWS Management Console with IAM Administrator permissions.
    Keep this tab active in your browser.
  2. Log in to the Viz Now and navigate to the panel Organization > Infrastructure tab > Manage IAM Roles.
    You’ll see a screen like the one below, where you can define the IAM Role ARNs for the Deploy and Control Plane functionality.
    Deploy role
  3. Update the inline policy:
    1. Switch to the AWS console IAM > Roles and from the Permissions tab, you can search for required inline policy.
      This is the same as in the Viz Now UI:
      Click it to open.
    2. Go back to Viz Now and in the Manage IAM Roles panel, next to Deploy Role, click the Question mark icon image-20250513-065709.png.
      and then Copy inline policy.
      (This saves the policy details to the clipboard).
    3. Switch back to the AWS Console Policy editor and click the JSON button.
    4. In the Policy editor, paste-in the inline policy from the clipboard.
    5. Click Next and then click Save changes.
    6. A confirmation message is displayed.
      Management Role
      You now repeat the same steps for the Management role.
  4. In Viz Now, next to the input field Management Role, click the Question mark icon image-20250513-065709.png.
    1. From the pop-up, click Copy inline policy.
    2. In the AWS Console, search for the required manage role, in this example, viz-now-manage, and click on it to display a Summary page.
    3. Select the Permissions tab and then its contained policy.
      The Policy editor page opens:
    4. Paste-in the inline policy that you copied to your clipboard, to update the JSON code.
      For an example, see the code below.
    5. Click Save changes.
  5. Validate IAM Role in Viz Now:
    1. Click Cancel.
    2. In Viz Now Manage IAM Roles panel, click Validate Roles.
    3. A confirmation message is displayed.
Permissions Explained
Deploy Role (viz-now-deploy-infra)
The Deploy role grants broad permissions to allow Spacelift to deploy infrastructure using Terraform. All permissions apply to all resources ("Resource": "*").
Permission
Purpose
Resource Scope
iam:*
Manages IAM roles/users
Scope to specific roles
s3:*
Manages S3 buckets
Scope to specific buckets
kms:*
Manages encryption keys
Scope to specific keys
route53:*
Configures DNS
Scope to specific zones
sts:*
Assumes roles
Necessary for Spacelift
ec2:*
Provisions EC2 resources
Scope to specific VPCs
tag:*
Applies tags
All (*)
logs:*
Manages CloudWatch logs
Scope to specific log groups
Manage Role (viz-now-manage)
The Manage role enables Viz Now to perform operational tasks on deployed instances. Permissions are scoped to specific resources whenever possible.
Key Tasks Enabled by Manage Role
  • Increase service quotas for AWS resources.
  • Reserve specific EC2 instance types.
  • Create S3 buckets for file storage.
  • Manage security groups for IP-based access.
  • Handle VPC peering.
  • Start, stop, or destroy instances.
  • Manage MediaConnect flows for streaming.
Permission
Purpose
Resource Scope
iam:*
Manages IAM configurations
All (*)
kms:*
All (*)
route53:*
Updates DNS
All (*)
servicequotas:*
Increases quotas
All (*)
s3:*
Manages S3 buckets
All (*)
ec2:*
Manages instances
All (*)
tag:*
Manages tags
All (*)
sts:*
Assumes roles
All (*)
logs:*
All (*)
ssm:SendCommand
Executes commands
SSM documents & tagged EC2 instances (VizNow=true)
ssm:ListCommandInvocations, etc.
Checks command status
All (*)
ssm:ListInventoryEntries, etc.
Retrieves instance details
Tagged resources (VizNow=true)
mediaconnect:CreateFlow
Creates MediaConnect flows
All (*)
mediaconnect:* (multiple)
Manages MediaConnect flows
Flows named VizNow-*
mediaconnect:ListFlows, etc.
Lists flows
All (*)
Additional Resources
