- Number of Feeds I/O allowed in the TriCaster Now to ensure the performance is as expected
- Combination supported SRT and NDI
- Type of TriCaster feature used (for example, the number of recording)
TO BE DETAILED
Learning from the performance test performed we need to provide users with a recommended combination of the number of streams, and quality protocols to avoid performance bottleneck
- Project Setting =
- Number of Monitors =
- Number of NDI inputs =
- Number of SRT Inputs =
- Number of M/E = 4
- Number of DSK layers enabled on the program output =
- Number of DDRs actively running =
- Number of active frame buffers used =
- Number of ISO records =
- NDI Bridge Encoder Setting = NDI | HX, H.264, High Quality@100%
- Number of NDI Mix Outputs =
- Number of SRT Streams = 1
- Streaming /Record configuration = 1920x1080, H.264, 7000 kbps, 59.94 fps
This is true for EC2 machines and computer users (for example, the NDI bridge) Preparing the Production Space
EC2 Types
EBS Sizing
Bandwidth (Internet)
Format | Max # of Streams | GPU % | CPU% |
1080p [59.94] | 16 | 73% | 38% |
1080p [59.94] | 26 | 97% | 72% |
2160p [59.94] | 1 | 88% | 10% |
1080p [50] | 16 | 73% | 34% |
1080p [50] | 32 | 99% | 74% |
2160p [50] | 1 | 88% | 9% |
