The new Template Editor is part of the Mosart Web Apps package. It is accessed and managed through the Configuration Tool. LAUNCH CONFIG TOOL on the installer's last screen opens it, and the desktop and Start menu shortcuts open it later.
  1. Open the Configuration Tool.
    On an installation that has not been configured yet, the Configuration Tool opens the Web Apps quick setup wizard. Finish it, or choose Skip setup, to reach Home, which shows all available applications. Template Editor is listed as one of the applications, but must be enabled before it becomes accessible.
  2. Enable Template Editor.
    1. Go to App Configuration.
    2. Select Template Editor.
    3. Review the important notes shown there before enabling. The application is in early access, and the notes describe its current limitations.
  3. Save and launch. Once you have enabled the Template Editor:
    1. Click Save. The change applies at once, with no restart.
    2. Once you have saved, the Open button becomes available. Click Open to launch Template Editor in your default browser, at /templateeditor on the Mosart Web Apps host.
  4. Confirm the template storage file location.
    Template Editor shares the template storage path configured on the NRCS Plugin page.
    • Ensure the Local file storage path is valid and accessible.
Info: Templates stored in a database are not supported in this version. Only file-based storage works with the Template Editor.
  1. Control access.
    As a web-based app, the new Template Editor is available to all users on the local network.
    • To control access, this version also offers authentication. Once configured, the permissions affect all Viz Mosart Web Apps.
Note: The Template Editor writes to the same channeltemplates.xml that your production uses. Back the file up before exploring, and prefer a staging environment. See the safety notes on Template Editor (Early Access).
