The Elgato Stream Deck plugin for Mosart Web Apps allows you to send Viz Mosart rundown actions including Start/Continue, Skip Next, Unskip Next, Take a template. You can also fire a Direct take or a Control command.
The plugin communicates directly with the Viz Mosart server and all actions are triggered without needing a Mosart GUI open, active or in focus.
For installation and operation, please refer to the latest Mosart Web Apps User Guide, in the Appendix.
This plugin runs as a Mosart Web App, not in the Viz Mosart GUI.
