The Viz Mosart User Interface may be started in several ways. Among these are
  • Clicking the shortcut Viz Mosart on the Desktop. (This shortcut will refer to the executable file MosartMultiGui.exe.)
  • Using the Windows Start menu.
Info: Advanced startup options require modifying the Desktop shortcut (or creating a new shortcut).
Creating and modifying shortcuts is beyond the scope of this guide, please consult your System Administrator or Windows documentation.
You can appended the following switches to a shortcut.
Each switch is prefixed with either the / (slash ) or - (dash ) character.
Command switch
Use
Example
Comment
browse
Start in browse mode
MosartMultiGui.exe -browse
This has the same effect as activating Browse mode from the View menu. The user can later deactivate Browse mode, unless this menu option has been disabled.
lang
Start with specific UI language
MosartMultiGui.exe /lang ja-JP
will start the UI in Japanese language
In addition to the default English language, a Japanese option is also available.
The language may only be specified before startup and cannot be changed once the UI is in use.
nosplash
Start without displaying the startup splash screen
MosartMultiGui.exe -nosplash
These options may be combined.
