When contacting support there is a standard naming convention for the following applications and components that form Viz Mosart:
Short Name | Long Name | Description |
AVA | AV Automation | Application controlling attached broadcast equipment. |
Client (output) | A client in this context denotes a service which are given access to one or more sources via the Media Router. In router terminology a client defines an output of a router matrix. | |
CurrentSalvo | Internal Media Router state containing validated crosspoints. | |
GUI | Viz Mosart GUI | Main user control application. |
Manus Admin | Manus Administrator | Application controlling the Viz Mosart rundown. |
Media Admin | Media Administrator | Application for monitoring media objects (clips). |
OGI | Overlay Graphics Interface | Application that controls Overlay graphics systems. |
PendingSalvo | Internal Media Router state containing all pending crosspoints (corresponding configuration changes to be validated by Mosart servers). | |
Source (input) | A dedicated media content provider to be controlled. Examples of sources in this context are video play-out server ports and graphics controllers. In router terminology a source defines an input of a router matrix | |
MMR | Mosart Media Router | Previously known as Mosart Media Router or MMR. Application that shares broadcast devices between control rooms. |
MMT | Media Router Test Application | |
NCS, NRCS | Newsroom Computer System | |
Salvo | A predefined list of crosspoint operations which when executed all occur simultaneously. |
