Installation
You install a Media Router from the Viz Mosart installer identified as
VizMosartMediaRouter-<version number>.msi
Configuration
MMR Configuration is performed in two xml-based configuration files:
Media Router service configuration
inMediaRouterServiceConfig.xml
Media Router Database Configuration
inMediaRouterDB.xml
Note: The name of
MediaRouterDB.xml
is configurable within the Media Router service configuration.
Normally both files are placed at:
%ProgramData%\Mosart Medialab\ConfigurationFiles
Info:
Older systems use a legacy location
C:\ChannelTemplates
