It is possible to activate predefined salvos, to set individual crosspoints and to get router information by entering appropriate console commands. The following commands are available:
  • autofailover: Toggles auto failover mode. See the MosartMediaRouterService configuration.
  • autotake: Toggle autotake mode. See the MosartMediaRouterService configuration.
  • clear: Clears the console window
  • command: Syntax: command cmd [arg1] [arg2]. Executes a Media Router command with two optional arguments. The following commands are available:
    • backup: Enforces a backup of the Media Router database
    • get <filename> : Retrieves the current Media Router database and stores the database using the given filename.
    • reset: Resets the Media Router to the latest Media Router database stored on the file system.
    • restore <filename> : Restores the Media Router database to the content of the database stored in the given filename
    • flush: Flushes the current content of the Media Router to file storage. This command may be used to set the initial state of the Media Router
  • deletesalvo: Syntax: deletesalvo salvo. Deletes the specified salvo
  • exit: Exits the Media Router
  • getconfig: Syntax: getconfig client. Returns the current configuration for the given client. Used mainly for testing Mosart Server clients
  • getstatus: Returns an xml string containing current Media Router status.
  • help: Lists all commands
  • idle: Toggles active / idle mode of the Media Router service. Used for testing
  • list: Syntax: list [salvos|clients|sources|inputs|outputs|all]. List various router information
  • restore: Syntax: restore <filename>. Restores the Media Router database to the content of the database stored in the given filename.
  • save: Syntax: save <filename>. Retrieves the current Media Router database and stores the database using the given filename.
  • setactive: Activates the Media Router service
  • setcrosspoint: Syntax: setcrosspoint inport outport [salvo]. Sets a crosspoint in the given salvo:
    • If no salvo is given then the pending salvo is used. I.e. a set crosspoint request is sent to corresponding clients.
    • If the given salvo is not present, a new salvo will be created.
  • setsalvo: Syntax: setsalvo salvo. Fires the specified salvo
  • verbose: Turns on/off verbose diagnostics
    Note when specifying crosspoints in console commands the inport/outport name shall be used to identify the corresponding port.
Media Router console command examples
  • List all current salvos: list salvos
  • List active connections: list salvos current
  • List pending connections: list salvos pending
  • List a specified salvo: list salvos M1.A
  • Connects video port M1.A.A to Quantel 2 / Port 1: setcrosspoint VS.Q2.1 M1.A.VA
  • Sets a crosspoint in a salvo: setcrosspoint VS.Q2.1 M1.A.VA M1.Backup
  • Fires a salvo: setsalvo M1.Backup
  • Deletes a salvo: deletesalvo M1.Backup
