Viz Mosart servers are normally configured in pairs in a redundancy setup. In most cases, configurations sent to both the Viz Mosart main and backup servers should be identical. In this way, both Viz Mosart servers are controlling the same devices.
In Media Router, main/backup redundancy setup requires both Viz Mosart servers to be configured as clients, with the same set of outports; and the configurations to both Viz Mosart servers be synchronized.
This requires Media Router to send the same configuration to both.
This is done by activating Mirror Mode
In Mirror Mode setting, a crosspoint related to one Viz Mosart server in a redundancy setup then the same configuration will be sent to both Viz Mosart servers.
Related service properties
  • MirrorMode: Set to True to activate Mirror Mode
  • MirrorModeMaster: Specifies which Viz Mosart server will receive crosspoint changes.
  • SynchronizedMirroring: If set, crosspoint changes related to any Viz Mosart server will be reflected to both.
