Installation
You install a Media Router from the Viz Mosart installer identified as
VizMosartMediaRouter-<version number>.msi
Configuration
MMR Configuration is performed in two xml-based configuration files:
Media Router service configuration
inMediaRouterServiceConfig.xmlMedia Router Database Configuration
inMediaRouterDB.xml
Info: The name of MediaRouterDB.xml is configurable within the Media Router service configuration.
Normally both files are placed at:
%ProgramData%\Mosart Medialab\ConfigurationFiles
Info: Older systems use a legacy location C:\ChannelTemplates
