The table tdfi_connection which contains a list of fields (or newsroomtags) that corresponds to a template description. See also information given in the td_templatedescription table.
This is a relation table defining a many-to-many relationship between the td_templatedescription and fi_field tables.
Name
Type
Allow Null
Description
tdfi_recno
integer
No
Primary key.
tdfi_td_recno
integer
No
Foreign key referencing the corresponding template description td_recno in the td_templatedescription table.
tdfi_fi_recno
integer
No
Foreign key referencing the corresponding field fi_recno in the fi_field table.
tdfi_default
varchar(128)
Yes
Optional default value for fields not of type ENUMERATION. I.e for STRING and NUMBER types.
tdfi_em_recno
integer
Yes
Optional foreign key for the default value for ENUMERATION field types. Reference to a enumeration value em_recno in the em_enumerationmember table.
