The ta_templatetypealias table contains custom user aliases for the Mosart template types. These aliases are used by Mosart ManusAdministrator to translate user aliases to the corresponding Mosart template types.
Name
Type
Allow Null
Description
ta_recno
integer
No
Primary key.
ta_name
varchar(32)
No
The template type alias name. Should be unique, as this is presented to the users.
ta_description
varchar(128)
Yes
Optional template type alias description.
ta_tt_recno
integer
No
Foreign key referencing the corresponding Mosart template type in the tt_templatetype table.
ta_default
smallint
Yes
A value of 1 is used for the ‘default’ alias among those belonging to the same template type. For each template type, exactly one alias belonging to that type should have ta_default = 1.
Information: The ta_templatetypealias table is the only table that is maintained and used by Mosart ManusAdministrator containing the NRCS template type aliases.
