You create templates as part of your show design. Use the Template Editor to configure the Viz Mosart templates.
From AV Automation, select Devices > Template editor.
A new application pane is displayed:From this view you can select the required template/template variant (with Template > Select) and work with the device settings as described in Template Device Functions.
Show design and detailed template topics are presented in section Show Design and Template Editor.
