Media Administrator, a console application, includes some command line-executable operations.
There should be no need to use these during daily operations, but they may be of help during installation or while investigating issues.
Info:
The list of available commands is as follows:
  • add <clipname> <index>: Adds a clip manually to the list of clips currently monitored. Typically used to test the installation.
  • delete <index>: Deletes a monitored clip with the given index.
  • dumpclips <filename>: Outputs a list of all monitored clips in an XML format. Outputs to console if no filename is given.
  • dumpprofiiler: Shows timing information. Typically used to test the installation.
  • exit: Exits the Media Administrator.
  • flushactionqueue: Flushes the internal action queue of all pending actions.
  • help: Outputs all available commands.
  • listactionqueue: Outputs the pending list of actions to be executed.
  • listclips: Outputs a list of all monitored clips.
  • listservers: Outputs a list of all configured media servers.
  • mmhost <hostname>: Sets the hostname of the Manus Administrator. Default: localhost.
  • postroll <roll>: Sets/displays the current value of the post roll.
  • reconnect: Reconnects to all configured media servers. Typically only one video server is connected.
  • reconnectadmin: Reconnects to the Manus Administrator.
  • refresh <seconds>: Resets all monitored clips and requests their status again from the video servers. Without an argument, the refresh runs once. With an argument, the refresh repeats at that interval in seconds until Media Administrator is restarted, or until refresh is run again with a new value. Typically used when testing an installation, or to force a re-check of clips that may have been deleted on a server that does not send notifications.
  • search <regex>: Issues a clip search to the video server. The regex is a regular expression for clip names. Typically used to test the installation.
  • set <property> <value>: Gets or sets a property while Media Administrator is running. Run set without arguments to list all properties with their current values. Changes last only until Media Administrator is restarted. Available properties:
    • UnresolvedClipRetryInterval: Retry interval, in seconds, for clips not yet found on any video server.
    • ServerReconnectDelay: Delay, in seconds, before retrying the connection to a disconnected video server.
    • ServerHeartbeatInterval: Heartbeat interval, in seconds, for connected video servers.
    • ManusAdminHeartbeatInterval: Heartbeat interval, in seconds, for the connection to Manus Administrator.
    • ManusAdminReconnectDelay: Delay, in seconds, before retrying the connection to Manus Administrator.
    • MonitorClipInterval: Interval, in seconds, for re-checking clips whose attributes are still changing. Monitoring stops when no change is detected.
    • MaxClipDurationForKeyFrames: Maximum clip duration for adding keyframe markers.
    • LoadDatabaseInterval: Stagger delay, in seconds, between video servers when loading clip databases at startup.
    The names and descriptions are from MainController.cs. The space-separated syntax is from the command's help string; the page currently shows <property>=<value>. Not yet tried on a live system.settings: Opens the Media Administrator Properties Editor.
  • verbose: Toggles verbose output. In Verbose mode, more information is logged to the console.
  • version: Outputs Media Administrator version and some system information.
